Specifies a sub-AS that should be deleted from a confederation.
| sub-AS-number | Specifies a sub-AS. |
N/A.
Before you can change the configuration with this command, you must disable the BGP neighbors in the confederation using the following command:
disable bgp neighbor [remoteaddr | all]The following command deletes a sub-AS from a confederation using the ASPLAIN 4-byte AS number format:
configure bgp delete confederation-peer sub-AS-number 65551
The following command deletes a sub-AS from a confederation using the ASDOT 4-byte AS number format:
configure bgp delete confederation-peer sub-AS-number 1.15
Support for 4-byte AS numbers was first available in ExtremeXOS 12.4.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.1.1 Licensing Guide document.
